Turning Up Disel Pump(Fuel)
kingman
Post by kingman »
Can anyone direct me as to how this is done and support this with some pics please?
I believe this is a special mod I would like to do,yet I cannot see exactly where this would be done.
wbski007
Re: Turning Up Disel Pump(Fuel)
Post by wbski007 »
Fuel adjustment screw is on back side of your injection pump, it will have a green tin cover over it that you must remove , then you'l see a sloted screw with a 12mm nut locking it in place ,loosen nut while holding screw with commom screw driver, once nut is loosened turn in screw one full turn and then tighten lock nut while holding screw in place, one turn should do it, then take for ride and check that you don't have too much smoke , if so just repeat procidure only back of screw a little. Take it for a ride first and see how much smoke it produces at full throtle and use that as a guide line on how much it changes after you turn it up.
cyberbeej
Post by cyberbeej »
looking for a bit of advice now that i know where to locate the fuel screw.
been reading through the forum and found info on turning up fuel to match a rise in boost pressure from 10psi standard to 15 psi.
my question is, can anyone suggest how much to turn the srcew as a starting point for fine tuning?
Oh, i drive a UK trooper 3.1 TD 1997, if this helps.
thanks in advance. BJ
wbski007
Post by wbski007 »
I start off with one full turn, that's usually enough, like I said up top, take it for a ride before you do any adjustments and see how much black smoke your putting out at full throttle, if any, then do the one full turn and check again, you don't want tons of black smoke, as you'll be just wasting fuel and not gaining any more power, remember black smoke is unburnt fuel!
cyberbeej
Post by cyberbeej »
my ride doesn't make any black smoke, is it just running well then?
so turn till black smoke then back off a quarter turn, does that sound about right?
thanks wayne
96 and 97 are probably electronic control. Limits the choises
cyberbeej
Post by cyberbeej »
If its electronicly controlled, if i tweak the boost will it compensate automaticly?
what are the limits? its the same as the pictue above with something electric attached, what is this bit?
wbski007
Post by wbski007 »
A little black smoke at full throttle is OK cybereej, you just don't want a whole lot of it.
scruff123
Post by scruff123 »
my 95 bighorn 3.1 is electronically controlled and turning up the boost doesnt make any difference, so it mustnt be able to compensate higher than standard settings, have to take it in to the dyno tuners for it to be done properly. its running 12 standard, what about yours?
also i couldnt find any fuel adjustment screw anywere, dont think they have one
they do Its under a cap. Increasing the fuel on that engine though also increases the idle speed
