Manual
If you need something post it here and maybe someone can help you out
55zed
Re: Manual
Post by 55zed »
I am considering buying a 3.0 Jackaroo fitted with the 4jx1 engine, has anyone got a repair manual
for the engine?
Cheers John
Re: Manual
buying a used vehicle with a 4jx1 is a bit like picking the winner of the horse race by putting the horses on the dart board putting a blindfold on having someone spin the board when you through the dart then putting your life savings on the result.
I know 2 people who had a good run from them. The others spent heaps on fixing them. Things like injectors computers sensors. None of these things are for the home mechanic.
I have a manual if you do buy it but warn that a good diesel mechanic must inspect this for you. Less than perfect walk away.
harryasaboy
Re: Manual
Post by harryasaboy »
Hi Guys. I'm after a workshop manual for a Holden Rodeo TFS55 '92 If possible.
Thanks in advance, either way.
Re: Manual
sent
harryasaboy
Re: Manual
Thanks Geeves!
Jimmyb
Re: Manual
Post by Jimmyb »
hi guys new to this forum i have a ubs69dw bighorn manual 4jg2t i am about to do the timing belt and have read most of the other post regarding this i like to be over prepped not under is it possible to get a copy of the manual for this engine thanks Jimmy
Re: Manual
bullseye
Re: Manual
Post by bullseye »
Hi, i have just bought my first 4x4, honda horizon 1995 3.1 diesel. Does anyone have owners or repair manual to start my library? Thanks very much.
bullseye
Re: Manual
Post by bullseye »
Actually, just found an awesome list from geeves, thanks, legend!
Re: Manual
for the car except engine use this
http://www.mediafire.com/?2g2hc1kzeyend
For the engine use this
http://www.mediafire.com/view/?32re54asslnsupk
