4GJ2 workshop manual
Re: 4GJ2 workshop manual
in your xtra account there is an engine manual. If you want everything please send me a pm with a postal address. Might not be able to send anything though till after easter
imckeenz
Post by imckeenz »
Hi, can you point me in th general direction of a manual for a 96 Wizard 4JG2 Auto. Thanks
workshop or owners?
imckeenz
Post by imckeenz »
Sorry,meant to say, Workshop. Thanks
send me a pm with your address and a cd will be in the mail
Eli101
Post by Eli101 »
HI i have 92 4jb1, please i need workshop manual? My turbo is pushing bout 4psi and i know nothing bout my vacuum tubes, most of them seem to not be working plus the waste gate. Many thanks from a beginner
engine manual heading to your hotmail
There is a pipe between the boost side of the turbo and the wastegate on the exhahst side Remove this hose block the holes and see if your boost improves. You should see something like 17+
Eli101
Post by Eli101 »
You wouldnt be able to show me an image or diagram would you? my wastegate doesnt move, at all, since ive owned it, and i know nothing about turbos, also there seems to be a rod/lever behind the turbo that my mate says needs to move to let out excess boost or something but that has never moved either. Any help with this issue is greatly appreciated.
Eli101
Post by Eli101 »
I removed that pipe and blocked the holes, only got bout 1psi xtra.
post a photo of how your boost guage is attached
Is performance ok?
