http://www.mediafire.com/?i36dwl1pkhb4g
is the workshop manual. I dont have an owners manual but there is a place selling these in Auckland via trademe. In the first post in this thread you will find a wizard owners manual Its about 80% the same
I suspect the Nissan manuals were the same as these with the manufacturer knowing nothing about them.
(most of these came from Russia but were found by someone from Chile)
manuals loaded to mediafire
Grasshopper
Re: manuals loaded to mediafire
Has anybody downloaded repair manuals from emanualonline.com and have they worked ok. They have manuals for Opel Montereys it appears in all the models.
Cost about $40.00 NZ to download with a money back guarantee if no good for seven days. I would assume everything on the Opel Monterey except the badges would be identical to Isuzu Bighorn?!
http://www.mediafire.com/?i36dwl1pkhb4g will save you $40
Diff ratios
G'day quick question have a 4jg2 ubs 69 would like to know the diff ratio front and back thanks in advance
either 4.3 or 4.56 depending on model. Most are 4.3 but my 94 is 4.56 from factory. Lift one back wheel and turn it one revolution while counting the turns of the driveshaft.Half the answer
I have just joined here and am stumbling thru the processes
I have a 2015 M-UX and am looking for the Driver's Manual... Owner's Manual
Am in the Dom Rep... and like the car -- used w/ 54k ms bought in January
I have the same warning symbol as posted elsewhere
A low fuel type symbol but in the upper dial and with a box of vertical lines under it
Would it be poor quality diesel ??
Anyway
Am searching for the answer to that and the manual
Thx for the help
Anyway
Thx for the help
Hi Geeves,
Do you have one that explains TOD and shows locations of transmission sensors etc.My data downloaded by holden points to faulty rear speed sensor in the transmission. Not entirely sure which sensor it is.
Rod
Rod
Thanks heaps geeves for helping and for all the info.
Have you come across any info for my new 97 lwb ubs69 wizard 4jg2 covec fuel pump?
I've read the bighorn info which lists codes and some associated faults but yet to find how to access the fault codes.
Hi there,
New member to this site & am searching for a workshop/service manual for 2016 MU-X.
Any advice on where to get one would be much appreciated.
The dmax one is probably as close as we can get
