TOD Check light diagnosis
Posted: Fri Jan 26, 2018 9:40 pm
by RADMAN
Hi There,
I have a 1997 Isuzu Vehicross Japan Import, it has been a very reliable beast until I jinxed it the other day commenting to the missus that it was the most reliable vehicle I had. Then 2 days later the TOD Check light comes on. I have had my sons GM Tech 2 Scan Tool on it with the Isuzu card but will only read engine data no transmission driveline codes. Took it to a mechanic and his SnapOn tool wouldn't talk to anything but the motor, I have an o2 sensor issue and have swapped it out for another but engine light just comes on with the non genuine sensor so put old one back in no light but on Scan Tool sensor reading is flat not pulsing rich/lean like it supposed to. But TOD is main issue at the moment. other symptom is TOD Check light won't come on most times unless you get it to 30kmh so my thoughts are leaning to wheel speed sensor but not sure which one, any ideas greatly appreciated. ;)
Re: TOD Check light diagnosis
Posted: Fri Jan 26, 2018 10:50 pm
I will have a look in my manuals when I get home. I should have something
Posted: Sat Jan 27, 2018 7:53 am
http://www.mediafire.com/?i36dwl1pkhb4g
This is the manual for the Bighorn but as far as I can tell the TOD is the same
If it doesnt help I do have the vehicross manual although really its a Frontera in a different body. I could upload it if required
