Isuzu Bighorn 3.1 4JG2i Check Engine Light' No Start
Posted: Fri Mar 30, 2018 11:36 am
I like to get help here on some issues that i am having with my 4WD Isuzu Bighorn 3.1 4JG2i Diesel Automatic
I have the Check-Engine Light comes on when i put key in the ignition and i see the Check-Engine light on and you can here the Governor/Actuator made a click off noise so i guess i am not getting power to it and the Fuel Cut-Off Solenoid. The Governor is new, Map Sensor New, Accelerator Pedal Position Sensor(TPS) is new, Camshaft Sensor is new, NP Sensor New on the Pump.
When i leave the leads off the battery for a day and hooked them back and go to start. I get no Check-Engine light. When i start it' all good idles nice, but after 30 Seconds it decide to Rev-out and shuts off and Check-Engine light comes on. Will not start back up unless you leave it for the day and it will do the same thing again.
I did get scan codes:21,34,31,35,27. Not sure what they mean. Any help would be great, Thanks
