Holden rodeo suspension will it fit?
Posted: Wed Sep 19, 2018 8:12 am
by mrMUMU
Looking at doing a full rebuild on my Mu. Has anyone used this suspension kit or something similar that would be interchangeable
https://rover.ebay.com/rover/0/0/0?mpre ... 1727777020
Re: Holden rodeo suspension will it fit?
Posted: Wed Sep 19, 2018 5:56 pm
by pig75
I think the early jackaroo is the same as MU. Rodeo has heaver rear springs and longer torsion bars
Posted: Thu Sep 20, 2018 2:31 am
This has come up so often. Jackeroo springs are too short and the ride is terrible plus the risk of inverting a shackle.don't know if rodeo fit but my guess is a 90ish model should be the same. Get the eye to eye measurement and compare it to how yours is sitting now. If the shackle has to be vertical or less to fit or if its past 45deg back then you need different springs
Posted: Thu Sep 20, 2018 7:47 pm
by mrMUMU
Ok great thanks for the reply. I better do a bit more research
Posted: Mon Sep 24, 2018 2:01 am
by tonkamu
I have lovells lifted springs with 90mm shackles. Has no sagged in 4 years, best springs I've had but only con is they are fricken hard like a flatbed ute over bumps.
Posted: Mon Sep 24, 2018 5:47 am
take a leaf out of the pack to soften them
Posted: Fri Oct 04, 2019 4:43 am
by AusZuMu
In case it's useful info for anyone.
A couple of weeks ago I fitted Tough Dog 45mm lift leafs meant for pre 97 TF Holden Rodeo and they are a perfect fit.
Posted: Sat Oct 05, 2019 9:25 pm
by Wazza556
I installed a Fulcrum kit on my 1993 Mu.
Fitting was easy and fitted like a glove.
Gave me 60mm lift in the rear.
https://fulcrumsuspensions.com.au/holde ... 0227832885
