Machanical gas pedal adjustment
LiveEvil
Post by LiveEvil »
Hi everyone,
I have a throttle cable in my wizard gas pedal. throttle cable is extended and also controls mechanical fuel pump (it was electric originally).
The car drives fine but gas pedal is a bit stiff and hard to push for long periods of time.
Since it is all mechanical what are my options to make it softer?
Re: Machanical gas pedal adjustment
First lubricate it well although if this was going to help it would also be sticking. You could try a counter spring assisting the foot pressure but look first at what you are pushing against. A lighter spring at the pump end might help but be cautious of it not having enough pull to pull the throttle back
LiveEvil
Post by LiveEvil »
geeves wrote:First lubricate it well although if this was going to help it would also be sticking. You could try a counter spring assisting the foot pressure but look first at what you are pushing against. A lighter spring at the pump end might help but be cautious of it not having enough pull to pull the throttle back
Thanks!
