Oil dipstick broke
Posted: Thu Oct 27, 2022 4:12 am
by lukemclaughlin
I have a 4JG2 and my oil dipstick has snapped at the lower of the two rivets on the handle. How can I remove the broken part of the dipstick? It’s about 8-10cm from the top of the tube. I don’t have needle nose pliers.
Re: Oil dipstick broke
Posted: Thu Oct 27, 2022 4:32 am
Where the dipstick tube enters the block you will find a bolt holding the tube in place. Undo this and pull out the whole assembly
Posted: Thu Oct 27, 2022 4:37 am
by lukemclaughlin
What’s the best way to access this bolt? Do I need to RTV the dipstick tube when I reinstall? Cheers
Posted: Thu Oct 27, 2022 5:26 am
long socket extension from memory. I cracked my dipstick tube at the joint. There is an o ring on the tube
Posted: Thu Oct 27, 2022 6:10 am
by lukemclaughlin
Awesome thanks, 12mm bolt holding the tubes brackets at the top and at the bottom of the tube, used a 3/8” socket with a short extension and regular 12mm socket so the total length was just longer than a 12mm deep socket. I accessed the bottom bracket from behind the front left wheel, slip under the running board and got both arms in to the area where the bolt was. My top bracket was broken so when I was driving the tube must’ve been vibrating and damaged the dipstick over time. There’s two O-rings at the bottom of the dipstick tube which keep it in place in the block. I removed the bottom bolt holding the tube in and also removed a hose halfway up the dipstick tube, I then pulled the tube straight up and removed the dipstick, I didn’t have to remove the top bracket bolt as the bracket was broken off, I reinstalled the tube just for the meantime till I can get a new tube and dipstick. Thanks for the help geeves
