SAS on the cheap
nb422
Re: SAS on the cheap
Post by nb422 »
Running mu rear leafs up fromt with 2 inch extended shackles. Need to swap out front crossmember i made to a beefier one, and these leaves in front are bent from being in the rear with a spring over. Am toying with the idea of kicking the leaves to the curb and installing radius arms and 10 inch coilovers, certing leaves is proving quite difficult.
mudslinger
Post by mudslinger »
hey jordan
can you go more into detail into how you retapered your steering box so your pitman arm is the opposite way? cheers
m27seo001
Post by m27seo001 »
nb422 wrote:IMG_0774.JPG
hah)
Im guessing you are struggling with local vocabulary. New Zealanders dont always talk English in a form that translates easily
Leaf springs from the back of the Mu used in the front with extended shakles
New front crossmember (not it the quote but there will be clearance issues to the driveshaft)
The leaf springs are bent because they were used in a spring over axle conversion
Thinking of not using the front leaves and going to radius arms and 250mm coil overs as certification for leaf springs is hard
nb422
Post by nb422 »
Pretty much finished product here. 80 series landcruiser front end and coilovers
tonkamu
Post by tonkamu »
that looks so cool, I wish I knew more about doing that. I've got an 03 hilux front end sitting next to my garage for a year now. so coils are better than leaf springs for conversion on a mu? how much are those coil springs they look like the price of a mu off trademe.
nb422
Post by nb422 »
Yeah not cheap haha. I paid aroun 1.5k for the pair from trundles. I went for coilovers for something different and i didnt like the feel of the leaves, nor the hassles it was gonna be for cert as far as bump steer tests etc
danz20
Post by danz20 »
Do u have an email looking at was on bighorn wouldn't mind asking you a few things
nb422 hasnt logged in since january. You could try the private message or email link when you click on his id but he might be gone
