Modifications and Accessories:
Pretty stock suspension and body work.
Bullbar, with small light bar.
Upgraded all lighting to LED
Engine:
Upgraded to 2.5 stainless straight thru exhaust and dump pipe from turbo
Stock turbo running higher boost
Front mount intercooler with stainless pipework
Custom intake manifold
Fueled up injector pump, other adjustments and......fuel, lots of fuel
Water/Methanol Injection, AEM controller and pump, Custom 18L under tray water/meth tank
Clutch upgraded to heavy duty NPC (it killed the Excedy HD pretty quick)
UPDATED: running compound turbo setup now, 46psi boost.
Clutch upgraded to a NPC cushioned ceramic (killed the NPC as well)
Diff ratio change to 3.72 RA Rodeo LSD
changed rear springs
Fitted traction bars
Also
Future upgrades:
Garrett VNT turbo
Intercooler water spray bar (may not need this with water/meth, need to do some testing)
fabricate air box for a high flow filter and snorkel
Diff ratio changes
Upgrade front brakes
Paul
