replace lower control arm bushes
skyna
Post by skyna »
I am going to attempt removing the lower control arm on my Mu, Can anyone give me advise on the best way to attack this job, I have read earlier posts an it is not an easy job but I am going to do it anyway. I have seen what needs to be unbolted but I would like to know is there a order of steps to follow? I have read that the old bushes are seated into the chassis is this correct if so what is the best way to remove them? Cheers
Re: replace lower control arm bushes
The bolts through the bushes should come out ok which will remove the arm. The bushes require a hydrolic press to get out
