Wanted 4jg2 crank pulley or called a harmonic balancer with the 4 holes for belt driven motor.
Tried couple places in NZ either don't have in stock or wont post over the ditch to Australia.
Cheers stardog
4jg2 td crank pulley
Re: 4jg2 td crank pulley
It is the same as the 4jb1 so maybe also later engines?. I broke mine on the wizard and replaced it from a 2.8 mu
Hi Geeves both the same 4 holes 3 belts but timing marks are different 2.8 setting is 12 degrees BTDC 3.1 is 0.5 degrees ATDC for timing the IP pump my crank pulley has spun so the timing marks are out.
I can get 1 in Auckland free postage in NZ on trade me but don't post to Australia .
If anyone redoes the timing on the old wizard they will be in for a surprise. I had the pullet separate the base from the rest and just bolted a new one on.
I think you could be right there it will confuse them with the timing marks on it and trying to dial in the pump for the timing lots of white or black smoke I think.
Problem is solved finally got a new pulley from NZ Big thanks to Steve from Isuzu part specialists in east Tamaki Auckland.
Fantastic guy to deal with and very helpful will be buying from again in the future when I need 4jg2t stuff .
