1993 Isuzu MU - remove rear - replace with soft top
JessJeanOW
Post by JessJeanOW »
Heya,
Anyone know if it’s possible to remove the rear windows and roof top of a 1993 Isuzu MU so it is “semi convertible” let’s say. Hoping to get a soft top made so it can be like the Amigo model. Unable to get my hands on an amigo so seeing what i can do!
Thank you :)
Re: 1993 Isuzu MU - remove rear - replace with soft top
Gen3 Mus had a soft top or fiberglass back. 89 mus had a ute back and could easily be converted. All the models in-between will require a few cut off blades in your grinder and advise from the certifier as to whether extra bracing is required
JessJeanOW
Re: 1993 Isuzu MU - remove rear - replace with soft topi
Thank you!
I’ll try find a certifier and get some tips as well.
Thanks again, good to hear it’s possible
Everything is possible. However are they all practical?
